Enable DiffServ so that the system provides DiffServ-based QoS on the port. By default, DiffServ is enabled.
Variable definitions
Use the data in the following table to use the enable-diffserv command.
Variable |
Value |
enable |
Enables DiffServ for the specified port. The default is enabled. |
port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
